How to use components
In version 6 of Grafana, the component lib is available in npm / yarn, I would like to know if I can only use it to develop new plugins in Grafana or in some of my applications, if possible, how to provide an example of the use of component Graph ?
hey
https://github.com/grafana/react-plugin-examples/tree/master/combo-panel
Kasmir,
Tks…
So I can to use components in my app?
yup, you just have to import the ones you want from @grafana/ui
