9.4.7 on linux -
Ultimately I want to create an alert when consumed container memory is above 90% of allocated container memory. Both allocated and consumed memory are available as time series -
What happened?
The expression E shows ‘no data’ as soon as I start combining $C and $D (by themselves C and D show data -
E should be a time series of the ratio, fluctuating between 0 and 1 depending on the amount of used memory -
Everything is in the screenshot -
There are no errors on screen, I have no access to the logs -
Documentation -
Write expression queries | Grafana documentation
DUH, looks like I can simplify this by calculating the ratio directly in the prometheus query:
container_memory_usage_bytes{marathon_app_id=~".*$service_name.*"} / container_spec_memory_limit_bytes{marathon_app_id=~".*$service_name.*"}
(will need to experiment a bit to prevent division by zero when some values are not avialable)
