how can i remove “-- Grafana --” datasource from explore ?
Grafana v 7.5.5
This is one of three special built in data sources. The mixed and dashboard data sources are the other two and they can be used in the query editor.
The Grafana data source can’t be toggled off or removed (at least not without changing the code).
thx Daniellee for your reply
