How can I get my apps authenticated by Grafana Service?
I write a program that accesses to Grafana, and
get alert info in json-format.
However,this program returns the following message.
Along with tutrial on the official site,
I added authentication info that specifies api key I generated to Http-Request header,Grafana may not recognize it.
message “Unauthorized”
Envirment
OS :Linux Mint 18.2
Grafana:v5.0.0(without Apache)
CODE in Python
#coding:utf-8
import json, urllib2
import requests
iparams={‘Authorization’:’ Bearer '}
url = ‘http://myserver/api/alerts
try:
# add api-key to the request header.
response = requests.get(url, params=iparams)
except Exception, e:
print e
You need to add your generated api key to the end of Bearer, like Authorization: Bearer eyJrIjoiT0tTcG1pUlY2RnVKZTFVaDFsNFZXdE9ZWmNrMkZYbk
Marcus
Thanks you, mefraisson,
I got wrong in the way how to my generated key to the App.
I should the key not to params, but to headers.
[Wrong Way]
[Corrected Way]
response = requests.get(url, headers=iparams)
after adding the key to headers,
my Apps successfully get alerts from Grafana.
