Invalid API key?
    Grafana open source in a container, itself in an Azure web app
    Using a Jupyter Notebook & Python, I would like to programmatically retrieve the list of dashboards in my Grafana instance, and for each of them, retrieve the JSON file that describes their layouts.
  • I created a Service Account in my Grafana, granted myself an Admin role, and generated a token.
  • Using Jupyter Notebook, I ran the following code:
headers = {"Authorization": f"Bearer {os.getenv(myToken)}"}
s = requests.Session()
s.headers = headers
r = s.get(url + "/api/search?query=&", headers=headers)
dashboards = r.json()
print(dashboards)
  • What happened?
    I’m getting this response:
'{"extra":null,"message":"Invalid API key","messageId":"api-key.invalid","statusCode":401,"traceID":""}\n'
    I expected my token to be a valid API key (I believe these terms share the same meaning?).
    I am not sure how to access the logs.
    I tried to follow:
  • Grafana’s documentation, although it does not provide Python code snippets;
  • this post
Can you please help? Thank you so much!
Thanks, I changed my headers line to:
headers = {
    "Authorization": "Bearer "+ myToken,
    "Accept": "application/json",
    "Content-Type": "application/json",
other lines of code remain unchanged.
And now the request works. Thanks!
