How can I create variables dynamically from my datasource plugin?
in case this is not possible so how can I populate a custom variable dynamically from a datasource plugin?
Welcome
for example you can do this using the query in your variable creation screen
name is countries
select name from countries
name the variable countries and it should be available as $countries with a list of country names.
What is your specific datasource?
