Assuming your input string is C:\ProgramFiles\Grafana-Labs\svc-11.5.0.0\nssm.exe
and you want to capture the sequence of numbers and dots that follows svc- and precedes \nssm.exe.
Try using the “Rename by Regex” transformation:
- Regex:
.*svc-(\d+\.\d+\.\d+\.\d+).* - Replacement:
$1
