Histogram with Limits
Hi every one, I’ve been able to plot a histogram using the graph panel. However adding threshold for the Specs limits became horizontal like the this,
We have a mysql database.
Is there an option to change limits from Y-axis to X-axis?
How can it be done?
Thank you for the support.
Hi guys.
I could not find a way to set the limits in the X-axis neither…
Is it possible? It’s quite common in case of histograms I think…
Thanks in advance!
Hi!
I have also tried to figure out how to mark a spesific column in the histogram barchart. With no success. I my case I want to show the target with another color. And the target must be read from the database (not static). Are there any other way around? Is it possible to have a second bar in the histogram chart? Or mark the target x-axis value with another color?
Thank you for the support!
The grafana didn’t support this funcation.
Maybe the future will support it?
