V8.0.5 -
To hide the panel title in the panel 'window" to make the embedded iframe look better in the HTML webpage. -
I am embedding graphs in an iFrame and using them in my website, I have tried editing the _dashboard.scss file in “/usr/share/grafana/public/sass/pages/” with no luck, I may have done that wrong though as this is very new to me. -
What happened?
Nothing changed, everything was still as it always was. -
The panels to load without a title/menu section. -
It should be all standard configs. -
None that I am aware of. -
Is it possible to hide the panel menu in dashboard-solo?
and
How could I check the built-in graph title font? - #2 by daniellee
