Help with updating from 2.6
Hi all,
I’m trying to upgrade Grafana2.6 to 4.x. so for the safe side i started to upgrade to 3.x
Running Centos, upgrading using Yum.
output:
Running Transaction
Updating : grafana-3.0.4-1464167696.x86_64 1/2
Cleanup : grafana-2.6.0-1.x86_64 2/2
Verifying : grafana-3.0.4-1464167696.x86_64 1/2
Verifying : grafana-2.6.0-1.x86_64 2/2
Updated:
  grafana.x86_64 0:3.0.4-1464167696
Complete!
[root@ ~]# sudo service grafana-server start
Starting Grafana Server: .... OK
No web page is laoding under port 3000.
I checked what the process running using: " ps -auxwe " and it seems that the config file is under:
/usr/sbin/grafana-server --pidfile=/var/run/grafana-server.pid --config=/etc/grafana/grafana.ini
I checked the Grafana.ini and it seems that it is the sample file and not the original one.
what can i do to solve it?
What do you mean it’s not the original one? Did you loose your settings? Did you answer Yes/No to the question during upgrade wether to overwrite the config file (default and recommended action is no).
Try restarting after upgrade:
sudo service grafana-server restart
Hi Torkel,
Now i can access the server only with local ip 192.168.0.1:3000 and not from any browser exmaple: myserver.com:3000
so it seems that it overwrite my settings. (Grafana didnt asked me about overwriting).
maybe a firewall issue?
The rpm upgrade never overwrite the config unless asked first, no reported instance of it happening so very strange.
i think it was IPTABLES issues, strange…
ok it seems to work now
Thanks anyway torkel !
