Help to developing a mqtt script in data manipulation plugin
Hello ,
is there a possibility to publish data in a mqtt topic with data manipulation plugin?
Do you have any example?
I found nothing more interesting in writing data to mqtt.
I think is the best plugin in data manipulation
I use Grafana 10.3.3
Thanks!
