v10.0.2 using public grafana/grafana-oss container image -
Expose private dashboards via a iframe using Port → Internal Developer Platform & Portal | Port (getport.io) -
By enabling JWT Authentication to read the JWT from the query stringauth_token -
What happened?
I get a 401 response from Grafana with response body{"message":"Invalid JWT","traceID":""}Looking at the console logs from Grafana I see this errorlogger=context level=warn msg="Invalid JWT" error="go-jose/go-jose: error in cryptographic primitive" traceID= -
I expected to get a 200 response and the dashboard to be loaded -
grafana.ini as follows
[paths]
data = /config/grafana
logs = /config/logs
plugins = /plugins
[server]
root_url = https://<redacted>
[database]
type = postgres
host = <redacted>.postgres.database.azure.com:5432
name = <redacted>
user = <redacted>
password = <redacted>
ssl_mode = require
[security]
allow_embedding = true
[auth]
disable_login_form = false
oauth_auto_login = false
[auth.anonymous]
hide_version = true
[auth.azuread]
name = Microsoft
icon = microsoft
enabled = true
auto_login = true
client_id = <redacted>
client_secret = <redacted>
auth_url = https://login.microsoftonline.com/<redacted>/oauth2/v2.0/authorize
token_url = https://login.microsoftonline.com/<redacted>/oauth2/v2.0/token
allowed_domains = "<redacted>"
use_pkce = true
[auth.jwt]
enabled = true
header_name = X-JWT-Assertion
jwk_set_url = https://login.microsoftonline.com/<redacted>/discovery/keys
expect_claims = {"iss": "https://sts.windows.net/<redacted>/"}
url_login = true
[azure]
cloud = AzureCloud
managed_identity_enabled = true
[smtp]
enabled = true
host = smtp.sendgrid.net:587
user = apikey
skip_verify = false
from_address = <redacted>
from_name = <redacted>
[external_image_storage.azure_blob]
account_name = <redacted>
account_key = <redacted>
container_name = <redacted>
[plugins]
plugin_admin_enabled = true
Yes - Front end{"message":"Invalid JWT","traceID":""}& backend consolelogger=context level=warn msg="Invalid JWT" error="go-jose/go-jose: error in cryptographic primitive" traceID=note the absense oftraceIDis what I found. -
Authentication | Port (getport.io)
The access token I receive from Azure AD OAuth2 endpoint (https://login.microsoftonline.com/<redacted>/oauth2/v2.0/token) is as follows
I’ve confirmed that the kid of value -KI3Q9nNR7bRofxmeZoXqbHZGew is present in the jwk_set_url response which is
"keys": [
"kty": "RSA",
"use": "sig",
"kid": "jS1Xo1OWDj_52vbwGNgvQO2VzMc",
"x5t": "jS1Xo1OWDj_52vbwGNgvQO2VzMc",
"n": "spvQcXWqYrMcvcqQmfSMYnbUC8U03YctnXyLIBe148OzhBrgdAOmPfMfJi_tUW8L9svVGpk5qG6dN0n669cRHKqU52GnG0tlyYXmzFC1hzHVgQz9ehve4tlJ7uw936XIUOAOxx3X20zdpx7gm4zHx4j2ZBlXskAj6U3adpHQNuwUE6kmngJWR-deWlEigMpRsvUVQ2O5h0-RSq8Wr_x7ud3K6GTtrzARamz9uk2IXatKYdnj5Jrk2jLY6nWt-GtxlA_l9XwIrOl6Sqa_pOGIpS01JKdxKvpBC9VdS8oXB-7P5qLksmv7tq-SbbiOec0cvU7WP7vURv104V4FiI_qoQ",
"e": "AQAB",
"x5c": [
"MIIDBTCCAe2gAwIBAgIQHsetP+i8i6VIAmjmfVGv6jANBgkqhkiG9w0BAQsFADAtMSswKQYDVQQDEyJhY2NvdW50cy5hY2Nlc3Njb250cm9sLndpbmRvd3MubmV0MB4XDTIyMDEzMDIzMDYxNFoXDTI3MDEzMDIzMDYxNFowLTErMCkGA1UEAxMiYWNjb3VudHMuYWNjZXNzY29udHJvbC53aW5kb3dzLm5ldDCCASIwDQYJKoZIhvcNAQEBBQADggEPADCCAQoCggEBALKb0HF1qmKzHL3KkJn0jGJ21AvFNN2HLZ18iyAXtePDs4Qa4HQDpj3zHyYv7VFvC/bL1RqZOahunTdJ+uvXERyqlOdhpxtLZcmF5sxQtYcx1YEM/Xob3uLZSe7sPd+lyFDgDscd19tM3ace4JuMx8eI9mQZV7JAI+lN2naR0DbsFBOpJp4CVkfnXlpRIoDKUbL1FUNjuYdPkUqvFq/8e7ndyuhk7a8wEWps/bpNiF2rSmHZ4+Sa5Noy2Op1rfhrcZQP5fV8CKzpekqmv6ThiKUtNSSncSr6QQvVXUvKFwfuz+ai5LJr+7avkm24jnnNHL1O1j+71Eb9dOFeBYiP6qECAwEAAaMhMB8wHQYDVR0OBBYEFGzVFjAbYpU/2en4ry4LMLUHJ3GjMA0GCSqGSIb3DQEBCwUAA4IBAQBU0YdNVfdByvpwsPfwNdD8m1PLeeCKmLHQnWRI5600yEHuoUvoAJd5dwe1ZU1bHHRRKWN7AktUzofP3yF61xtizhEbyPjHK1tnR+iPEviWxVvK37HtfEPzuh1Vqp08bqY15McYUtf77l2HXTpak+UWYRYJBi++2umIDKY5UMqU+LEZnvaXybLUKN3xG4iy2q1Ab8syGFaUP7J3nCtVrR7ip39BnvSTTZZNo/OC7fYXJ2X4sN1/2ZhR5EtnAgwi2RvlZl0aWPrczArUCxDBCbsKPL/Up/kID1ir1VO4LT09ryfv2nx3y6l0YvuL7ePz4nGYCWHcbMVcUrQUXquZ3XtI"
"kty": "RSA",
"use": "sig",
"kid": "2ZQpJ3UpbjAYXYGaXEJl8lV0TOI",
"x5t": "2ZQpJ3UpbjAYXYGaXEJl8lV0TOI",
"n": "wEMMJtj9yMQd8QS6Vnm538K5GN1Pr_I31_LUl9-OCYu-9_DrDvPGjViQK9kOiCjBfyqoAL-pBecn9-XXaS-C4xZTn1ZRw--GELabuo0u-U6r3TKj42xFDEP-_R5RpOGshoC95lrKiU5teuhn4fBM3XfR2GB0dVMcpzN3h4-0OMvBK__Zr9tkQCU_KzXTbNCjyA7ybtbr83NF9k3KjpTyOyY2S-qvFbY-AoqMhL9Rp8r2HBj_vrsr6RX6GeiSxxjbEzDFA2VIcSKbSHvbNBEeW2KjLXkz6QG2LjKz5XsYLp6kv_-k9lPQBy_V7Ci4ZkhAN-6j1S1Kcq58aLbp0wDNKQ",
"e": "AQAB",
"x5c": [
"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"
"kty": "RSA",
"use": "sig",
"kid": "-KI3Q9nNR7bRofxmeZoXqbHZGew",
"x5t": "-KI3Q9nNR7bRofxmeZoXqbHZGew",
"n": "tJL6Wr2JUsxLyNezPQh1J6zn6wSoDAhgRYSDkaMuEHy75VikiB8wg25WuR96gdMpookdlRvh7SnRvtjQN9b5m4zJCMpSRcJ5DuXl4mcd7Cg3Zp1C5-JmMq8J7m7OS9HpUQbA1yhtCHqP7XA4UnQI28J-TnGiAa3viPLlq0663Cq6hQw7jYo5yNjdJcV5-FS-xNV7UHR4zAMRruMUHxte1IZJzbJmxjKoEjJwDTtcd6DkI3yrkmYt8GdQmu0YBHTJSZiz-M10CY3LbvLzf-tbBNKQ_gfnGGKF7MvRCmPA_YF_APynrIG7p4vPDRXhpG3_CIt317NyvGoIwiv0At83kQ",
"e": "AQAB",
"x5c": [
"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"
"kty": "RSA",
"use": "sig",
"kid": "DqUu8gf-nAgcyjP3-SuplNAXAnc",
"x5t": "DqUu8gf-nAgcyjP3-SuplNAXAnc",
"n": "1n7-nWSLeuWQzBRlYSbS8RjvWvkQeD7QL9fOWaGXbW73VNGH0YipZisPClFv6GzwfWECTWQp19WFe_lASka5-KEWkQVzCbEMaaafOIs7hC61P5cGgw7dhuW4s7f6ZYGZEzQ4F5rHE-YNRbvD51qirPNzKHk3nji1wrh0YtbPPIf--NbI98bCwLLh9avedOmqESzWOGECEMXv8LSM-B9SKg_4QuBtyBwwIakTuqo84swTBM5w8PdhpWZZDtPgH87Wz-_WjWvk99AjXl7l8pWPQJiKNujt_ck3NDFpzaLEppodhUsID0ptRA008eCU6l8T-ux19wZmb_yBnHcV3pFWhQ",
"e": "AQAB",
"x5c": [
"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"
"kty": "RSA",
"use": "sig",
"kid": "OzZ5Dbmcso9Qzt2ModGmihg30Bo",
"x5t": "OzZ5Dbmcso9Qzt2ModGmihg30Bo",
"n": "01re9a2BUTtNtdFzLNI-QEHW8XhDiDMDbGMkxHRIYXH41zBccsXwH9vMi0HuxXHpXOzwtUYKwl93ZR37tp6lpvwlU1HePNmZpJ9D-XAvU73x03YKoZEdaFB39VsVyLih3fuPv6DPE2qT-TNE3X5YdIWOGFrcMkcXLsjO-BCq4qcSdBH2lBgEQUuD6nqreLZsg-gPzSDhjVScIUZGiD8M2sKxADiIHo5KlaZIyu32t8JkavP9jM7ItSAjzig1W2yvVQzUQZA-xZqJo2jxB3g_fygdPUHK6UN-_cqkrfxn2-VWH1wMhlm90SpxTMD4HoYOViz1ggH8GCX2aBiX5OzQ6Q",
"e": "AQAB",
"x5c": [
"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"
"kty": "RSA",
"use": "sig",
"kid": "lHLIu4moKqzPcokwlfCRPHyjl5g",
"x5t": "lHLIu4moKqzPcokwlfCRPHyjl5g",
"n": "xlc-u9LJvOdbwAsgsYZpaJrgmrGHaEkoa_3_7Jvu4-Hb8LNtszrQy5Ik4CXgQ_uiLPt4-ePprX3klFAx91ahfd5LwX6mEQPT8WuHMDunx8MaNQrYNVvnOI1L5NxFBFV_6ghi_0d-cOslErcTMML2lbMCSjQ8jwltxz1Oy-Hd9wdY2pz2YC3WR4tHzAGreWGeOB2Vs2NLGv0U3CGSCMqpM9vxbWLZQPuCNpKF93RkxHj5bLng9U_rM6YScacEnTFlKIOOrk4pcVVdoSNNIK2uNUs1hHS1mBXuQjfceghzj3QQYHfp1Z5qWXPRIw3PDyn_1Sowe5UljLurkpj_8m3KnQ",
"e": "AQAB",
"x5c": [
"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"
I’ve tried changing
[log.console]
level = debug
but this did not give any more output to the console. In fact it reduced it.
The request sent to Grafana that results in a 401 looks like this
https://<redacted>/d/<guid>/<name>?orgId=1&var-Pool=39&var-interval=1d&from=now-90d&to=now&auth_token=<redacted>
How can I diagnose why Grafana evaluates this JWT to be invalid? Anyway to get more error detail?
