Help about alert rule's UQE_alert_rule_version_rule_guid_version
  1. My Grafana has been upgraded several times, perhaps from version 8.X to 10.X.
  2. Now, let me introduce my environment and how to start Grafana.
  3. Grafana: 10.4.15, OS: Ubuntu 22.04, Browser: Chrome Version 134.0.6998.35 (Official Build) (64-bit)
  4. docker run -d --name=grafana -p 3000:3000 -v /opt/grafana/grafana.ini:/etc/grafana/grafana.ini -v /data1/grafana-data/plugins:/var/lib/grafana/plugins grafana/grafana:10.4.15
  5. What is the incorrect visualization?
  6. When adding a new alert rule, there seems to be an issue. In fact, the value of the guid column in the alert_rule table is empty, and the value of the rule_guid column in the alert_rule_version table is also empty. Currently, for the unique constraint UQE_alert_rule_version_rule_guid_version, the rule_guid value is empty and the version column value is set to ‘1’.
  7. I just added one alert rule.
SELECT  * from alert_rule  order by id desc limit 1;
id |org_id|title|condition|data        |updated            |interval_seconds|version|uid           |namespace_uid|rule_group|no_data_state|exec_err_state|for         |annotations                                       |labels|dashboard_uid|panel_id|rule_group_idx|is_paused|notification_settings|record|metadata|updated_by|guid|
829|     1|空间使用率|D        |[{"refId":"A","queryType":"","relativeTimeRange":{"from":3600,"to":0},"datasourceUid":"5VBDG8eMz","model":{"datasource":{"type":"prometheus","uid":"5VBDG8eMz"},"disableTextWrap":false,"editorMode":"builder","exemplar":true,"expr":"address_device_fstype_mo|2025-03-14 02:27:54|             300|      1|defru3x8cc4xsf|78kYmsuMz    |5m        |NoData       |Error         |300000000000|{"__dashboardUid__":"4Qv2-YBnk","__panelId__":"9"}|{}    |4Qv2-YBnk    |       9|             1|        0|null                 |      |        |          |    |
SELECT  * from alert_rule_version   order by id desc limit 1;
id  |rule_org_id|rule_uid      |rule_namespace_uid|rule_group|parent_version|restored_from|version|created            |title|condition|data        |interval_seconds|no_data_state|exec_err_state|for         |annotations                                       |labels|rule_group_idx|is_paused|notification_settings|record|metadata|created_by|rule_guid|
1308|          1|defru3x8cc4xsf|78kYmsuMz         |5m        |             0|            0|      1|2025-03-14 02:27:54|空间使用率|D        |[{"refId":"A","queryType":"","relativeTimeRange":{"from":3600,"to":0},"datasourceUid":"5VBDG8eMz","model":{"datasource":{"type":"prometheus","uid":"5VBDG8eMz"},"disableTextWrap":false,"editorMode":"builder","exemplar":true,"expr":"address_device_fstype_mo|             300|NoData       |Error         |300000000000|{"__dashboardUid__":"4Qv2-YBnk","__panelId__":"9"}|{}    |             0|        0|null                 |      |        |          |         |
  1. Now, when I try to add the second alert rule, it shows the error Failed to save rule: conflicting alert rule found [rule_uid: 'eefruevl38wzkc', title: 'Load5', namespace_uid: '78kYmsuMz']: rule title under the same organisation and folder should be unique.
It’s duplicate here. Do not know how to delete this post.
