What happened?
Welcome to the
community support forums !!
As to improve the community forums we advise and encourage all our members to fill out the template so that we can know more information about what exactly you are looking for.
Understanding from your post subject title, Yes, it is possible to connect your on-prem K8s cluster to the Grafana cloud.
Kindly check the documentation regarding it i.e.
Also, some good quickstart guides as well:
I hope this helps.
