Heatmap in dashboard not showing bars
Hi, I’m on Grafana v11.0.0, new to this forum so please bear with any non-alignment to protocols. I have a dashboard with a heatmap which accesses elasticsearch, and a heatmap which accesses the singlestore database log. Both sources should produce similar stats for a given time range.
In our QA environment, I get expected expected results per the attached screenshot below, bars appear and are reasonably aligned between the 2 charts.
I cloned the QA dashboard to our UAT environment. Now, the elastic-sourced one still renders fine, but the database-sourced one is not showing bars, even though the Y-axis labels are there and the legend shows reasonable min and max values for the average response that should be plotted. Result is per attached screenshot below, any idea why this would happen?
