Grafana v8.0.6 docker image. -
I’d like a variable with 2000 options. -
In the variable query I have
import "influxdata/influxdb/v1"
v1.tagValues(
bucket: v.bucket,
tag: "my_tag",
predicate: (r) => true,
start: -1d
What happened?
Only 1001 options are available in the variable select box. -
My 2000 options to be available in the select box. -
In the browser network tag I got the error
A query returned too many datapoints and the results have been truncated at 1001 points to prevent memory issues. At the current graph size, Grafana can only draw 100.
- Did you follow any online instructions? If so, what is the URL?
Grafana v7.4.3 Variable "returned too many points in a series" but it only works for query in a panel, not in a variable.
