v8.3.4
I want a user friendly variable containing service names which controls multiple hidden variables containing values to be used in a panel query.
Is this possible without an external datasource? I’m using graffonet to generate my dashboard and it will be much easier to hardcode these relationships. I see several solutions online about doing this using prometheus, SQL, etc.
Example:
variable #1:
- Name: services
- Type: custom
- Values: serviceA, serviceB, serviceC
variable #2:
- Name: namespace
- Type: custom
- Values: serviceA : namespaceA, serviceB : namespaceB, serviceC : namespaceC
variable #3:
- Name: loggroup
- Type: custom
- Values: serviceA : logGroupA, serviceB : logGroupB, serviceC : logGroupC
when a user selects variable $services=serviceA, variable values are:
- $service = serviceA
- $namespace = namespaceA
- $loggroup = logGroupA
As far as I can tell, you can’t retrieve values from one variable by using another variable as the key such as $loggroup.${service}. Sorry if I’m missing something obvious, help is appreciated!
