Handle cors issues
I have found several issues on Grafana’s Github page. However, none of them worked.
I’m using nginx (actually is nginx-proxy by jsonwilder)
What I want to do:
Consume Grafana API from my very own backend/frontend. I’m creating a system that will consume grafana api and load render images from selected dashboard (and panels) and send a e-mail with them.
What issues i’m having:
CORS problem. I can’t consume Grafana API from my backend and from my frontend cuz of cors.
What I’m trying to do:
Using nginx reverse proxy I can’t set the CORS header to enable the communication. However, the reverse proxy seems to be working OK. When I send request to the nginx-proxy, they are redirected to grafana endpoint and everything works.
Howerver, I can’t assure if the header is been setted.
Generic answer (because no exact request/error is provided):
https://enable-cors.org/server_nginx.html
You may need to customize this config - check preflight request what is requested and customize accordingly.
