HA Grafana, two servers one MySQL db
#1
As Grafana tutorial site: http://docs.grafana.org/tutorials/ha_setup/ is not very helpful in this matter: If I want two Grafana instances talking to single MySQL db, do I need to do anything special or just:
[database]
type = mysql
host = 1.2.3.4:3306
name = grafana
user = user
password = password
[session]
provider = mysql
provider_config = user:password@tcp(1.2.3.4:3306)/grafana
in the grafana.ini config file should be enough?
Edit:
Users are kept in LDAP if that makes any difference.
#2
If you use v6.0 you do not need the session part either.
A shared MySQL server should be all you need
