Cloud with Ubuntu 22.04 Linux
- What are you trying to achieve?
Monitoring of Corosync Pacemaker cluster
- How are you trying to achieve it?
Attempting to use ha cluster exporter and scraping that through the grafana agent
- What happened?
No data returns, from the dashboard template from the cluster labs dashboard but Data returns if I run queries from Grafana manually.
To see data in the dashboard
- Can you copy/paste the configuration(s) that you are having problems with?
- Did you receive any errors in the Grafana UI or in related logs? If so, please tell us exactly what they were.
Just no data and query variable not showing any preview.
- Did you follow any online instructions? If so, what is
GitHub - ClusterLabs/ha_cluster_exporter: Prometheus exporter for Pacemaker based Linux HA clusters
Then configured Grafana Agent job to collect on the port for ha cluster exporter.
