For an automation project which consists of test results for multiple subsystem (15-20 ), we would like to have visualization / dashboards for each of the subsystems
Below are the high level requirements :-
- Able to create / update dashboards for each subsystem
- Able to add/remove different type of widgets like table , line charts , bar charts etc. for different reports
- Able to save templates for different type of widgets e.g. saved template in DB can be monitoring 1 parameter and and then if user want to monitor 2 parameters , change the width or height , add two y axis etc. update the template and save to DB.
- User has personal workspace where templates can be saved but there will be approved templates at global level also.
- Able to download / upload the original data sets .
For above requirements , we explored platform like grafana .
However we feel grafana is overkill and we don’t need all the features like query editor , alerts etc . Also we don’t need to support multiple data source and in our application only one data source ( postgres DB ) will be present which will have different tables and relation ships defined . From backend we need to fetch the data based on the filter criteria provided .
However we like the overall approach of having plugin architecture of ability to add / remove dashboards , panels etc. and want to support the same .
Similarly grafana have query editor , however we would like to have is that a user using gui / rest endpoints call , should be able to fetch the filtered data for different type of widgets instead of writing SQL queries .
Is there any way which supports these requirements ? Are we on right track ?
Thanks in advance !
