I’m trying to use Loki to generate visualisations from a service’s event logs. I have written a script that authorises and parses the JSON API of the service, and dumps the results into a file on disk. Using jq I can either choose to analyse these logs in .csv or .json format - and I think that .csv is going to be easier.
Here’s an example of the logs:
event,1108,0deba616-9f81-488f-81c1-af4a01040347,,,,,83cd55a9-95bf-4eb5-a221-af4900c54bf7,,2022-11-11T15:46:48.175Z,10,xxx.xxx.172.92
event,1107,0deba616-9f81-488f-81c1-af4a01040347,,,,,83cd55a9-95bf-4eb5-a221-af4900c54bf7,,2022-11-11T15:46:46.856Z,10,xxx.xxx.172.92
event,1100,0deba616-9f81-488f-81c1-af4a01040347,,,,,83cd55a9-95bf-4eb5-a221-af4900c54bf7,,2022-11-11T15:46:40.6766667Z,10,xxx.xxx.172.92
event,1115,f812baad-6e31-4fac-8c8a-af4a0103a7f4,,,,,83cd55a9-95bf-4eb5-a221-af4900c54bf7,,2022-11-11T15:45:38.63Z,10,xxx.xxx.172.92
event,1107,f812baad-6e31-4fac-8c8a-af4a0103a7f4,,,,,83cd55a9-95bf-4eb5-a221-af4900c54bf7,,2022-11-11T15:45:36.167Z,10,xxx.xxx.172.92
event,1108,f812baad-6e31-4fac-8c8a-af4a0103a7f4,,,,,83cd55a9-95bf-4eb5-a221-af4900c54bf7,,2022-11-11T15:45:33.908Z,10,xxx.xxx.172.92
event,1107,f812baad-6e31-4fac-8c8a-af4a0103a7f4,,,,,83cd55a9-95bf-4eb5-a221-af4900c54bf7,,2022-11-11T15:45:32.908Z,10,xxx.xxx.172.92
I’ve scraped the logs into Loki using promtail, and added labels using the following pattern
`<event>,<eventType>,<itemId>,<collectionId>,<groupId>,<policyId>,<memberId>,<actingUserId>,<installationId>,<date>,<device>,<ipAddress>`
I’d now like to create a visualisation of the various event types - say a timeseries chart of eventType=1000, a graph of the most accessed itemIds etc.
I’m a bit stuck at this point - a query that I thought should work:
count_over_time({filename="/var/xxxlogs/eventLogs/event_logs.csv"}
| pattern `<event>,<eventType>,<itemId>,<collectionId>,<groupId>,<policyId>,<memberId>,<actingUserId>,<installationId>,<date>,<device>,<ipAddress>` [1m]) by (eventType)
gives a grouping not allowed for count_over_time aggregation error.
I’d be most grateful if anybody could give me some ideas or suggestions as to how to produce visualisations based on this data. At the moment my knowledge is limiting me to logs!
