sum (count_over_time({filename=“/var/log/nginx/access.log”}[1m]
| pattern <_> <_> "<_> <request> <_>" <_> <_> "<_>" "<_>" "<_>" <_> <_>
|~ “/json//users/*********” - User id here
)) by(request)
Hi @asivolobov,
Welcome to the community support forums !!
Please review the submission template and include more details:
- What is your datasource?
- What visualization panel you are using e.g. time-series, bar chart, histogram etc?
- What are you trying to achieve?
- How are you trying to achieve it?
- What happened?
- Can you copy/paste the configuration(s) that you are having problems with?
- Did you receive any errors in the Grafana UI or in related logs? If so, please tell us exactly what they were.
- Did you follow any online instructions? If so, what is the URL?
