I am a new user and trying to setup Grafana with ES. While doing the dashboard, I came across an issue of grouping data on monthly/yearly basis over a timestamp field. ES and Grafana are both version 7.
v7 -
Group ES log data in table view on monthly/yearly basis over a timestamp field values. -
Through query metric panel -
What happened?
The time portion within the timestamp values is breaking the group. -
There must be a date format so as to group on YYYY or MM basis only. -
not exactly. -
just the normal docs available online.
Any help/guidance will be highly appreciated.
Thanks,
MN.
