Grouping data in a table by conditions
I have a table that has Ages of people and the Count of people with that age. I want to simplify the table by creating age ranges (e.g. 0-4, 4-12, 13-18, etc.). I have played around with a few different transformations within Grafana, but none of them worked. I am not able to change the query for the data at all.
You might want to check out the new SQL expression to group by ranges
I’m not using a SQL database. I am using Elastic Search with Lucene queries
See this
OH, that’s very cool. Thank you. I’ll read through it. Quick question. Do you know if you can use that to get data after a transformation already? And then do more transformations after the SQL expressions.
My method is never ever use transformation unless the datasource does not provide a means to get what you need.
Sql expression is pretty much the answer to transformations
Thank you very much. I am running into a small issue when I try to do it. My field name for age is ‘tag.age.keyword’ and when I try to put that in SQL I am getting an error, I am going to read up on SQL and see if/how I can fix this, but if you know the answer and can help me that’d be great.
EDIT: Got it, nvm, thanks
EDIT2: I am running into this error now `[sse.sql.input_limit_exceeded] sql expression [F] was not run because the number of input cells (columns*rows) to the sql expression exceeded the configured limit of 100000` do you know how to fix this?
What does your sql query look like?
SELECT COUNT(*) AS how_many_peeps,
    CASE
      WHEN age = '4_12' THEN '4_12'
      WHEN age = '13_18' THEN '13_18'
      WHEN age = '19_30' THEN '19_30'
      WHEN age = '31_50' THEN '31_50'
      WHEN age = '50+' THEN '50+'
      WHEN age BETWEEN 0 AND 3 THEN '0_3'
      WHEN age BETWEEN 4 AND 12 THEN '4_12'
      WHEN age BETWEEN 13 AND 18 THEN '13_18'
      WHEN age BETWEEN 19 AND 30 THEN '19_30'
      WHEN age BETWEEN 31 AND 50 THEN '31_50'
      WHEN age > 50 THEN '50+'
     ELSE age END AS age_group
FROM (
    SELECT `tags_object.age.keyword` AS age FROM A
    UNION ALL
    SELECT `tags_object.age_2.keyword` AS age FROM B
) combined
GROUP BY age_group;
  1. Remove Union all
  2. Add LIMIT 100 at the end of the query for test purposes
It works with just A. The issue is that I am using it on a VERY large table (~50,000 rows and 3 columns) that just happens to be split into a few smaller ones. So if I run it on each smaller one first and then combine them it works. But if I combine first then I get that error since there are more than 100,000 cells. The question is where/how to change that 100,000 limit.
Probably cannot. Why would you need 100k
Because that’s what my data is in total. 500k is actually just a small part of my database. The whole database in Elasticsearch has over 150M documents.
I would file a bug for this ghat is still in Preview
