Grouped and stuck data by days
I have rather simple query (Postgresql):
select created_at, category, sum(profit) as profit
from datasource
group by created_at, category;
I want to create a chart which represents profit per category for every day. I tried to use a time series but I couldn’t stack them. Also I tried to use a bar chart (unsuccessfully). So technically I even didn’t find a way to represent categories with profit inside one date.
How could I do it in Grafana?
Welcome to forum @tylinka
try this
select created_at as time,
       category as metric,
       sum(profit) as value
  from datasource
and make sure your data format is time series
Did you set any additional settings? I used this aliases but still have the same :frowning: I tried to override and use stack option, but it doesn’t help.
Did you set tha format?
Yes, it has date time format
Nope not that. See the previous picture I posted
Right below there is a Format option
Wow, I’ve never noticed that… Thank you very much!
Would be nice if it defaulted to time series when it sees a time column
