I have two timeline panels with the same source data but on one I have joined two metrics and that results in the values graphed being 10000 time higher? heres the two graphs:
Top one is just a single metric query : NutanixVms_stats_hypervisor_cpu_usage_ppm{hostUuid=“0166200e-9b72-49a2-96d8-0f45ad5ed5c2”}/10000
this panel is displaying the correct CPU values for the three vms
the lower panel i have tried to pull the hostname in from another set of metrics using this query:
(NutanixVms_stats_hypervisor_cpu_usage_ppm{hostUuid=“0166200e-9b72-49a2-96d8-0f45ad5ed5c2”} * on(hostUuid) group_left(host) (label_replace(NutanixHosts_stats_hypervisor_cpu_usage_ppm, “hostUuid”, “$1”, “uuid”, “(.*)”)))/10000
but this messes up all the values for some reason ? is there another way to pull the hostname into these metrics without messing up the values ?
Thanks
Hi, by using * on()...
you’re actually executing multiplication - that’s why you have the values messed up. You could do
(NutanixVms_stats_hypervisor_cpu_usage_ppm{hostUuid=“0166200e-9b72-49a2-96d8-0f45ad5ed5c2”} + (on(hostUuid) group_left(host) (label_replace(NutanixHosts_stats_hypervisor_cpu_usage_ppm, “hostUuid”, “$1”, “uuid”, “(.*)”)) * 0))/10000
(or so with parentheses) so that the right-side value does not give any values (addition with 0 will be the same).
Just a follow on, when a VM moves between Hosts the graph still displays the last value making it look like the CPU for example is running constantly at 25% :
these two graphs show one VM moving between two hosts
I am guessing its related to the group_left function somehow?
Thanks
I’m not quite sure - have you tried to remove the whole +...
expression? I would guess that it’s more of how the metrics are reported? Maybe even after the move, the VM is still reported as constant in the element of the infrastructure that reports metrics? It would be best to see at the reporter (source) if the series for the VM are still there.
Bingo, the problem is with the collector as it only builds the indexes on startup, if i restart the collector its all fixed. So all good with the querys.
Thanks
