I’ve got statsd hooked up to Graphite, added as a Grafana datasource. It works well, except that the variable don’t work.
For example, this doesn’t work :
aliasByNode(stats.gauges.servers.$Servers.apps.$Applications.metrics.akka.systems.$ActorSystems.dispatchers.$Dispatchers.actors.$Actors.mailbox-size.$MetricType, 3, 5, 9, 13, 15)
while this works :
aliasByNode(stats.gauges.servers..apps..metrics.akka.systems..dispatchers..actors.*.mailbox-size.$MetricType, 3, 5, 9, 13, 15)
I can’t find where that index is being kept, and who updates it. For some reason, it doesn’t build in this case. I want to force a rebuild, so that the dashboard dropboxes start working.
Can anyone shed a light on how this works, and how to solve the not-showing issue ?
Regards,
Igmar
