[Graphite] Cannot read properties of undefined (reading 'get')
v9.1.3
Adding a Graphite Datasource
  • What happened?
    I’m getting the Error Message “Cannot read properties of undefined (reading ‘get’)”
The Port 89 ist mappet to Port 80 (Graphite Web)
I am also facing same issue, is there anyone able to solve it ?
I am having the same issue, have you figured it out yet?
I’m in the same boat. Anyone have a solution yet?
I have the same problem. Running both Graphite and grafana in docker containers on RPI3.
To clarify: I am running Grafana v9.1.6 and Graphite v1.1.10-3. Using default docker installs of both applciations (graphiteapp/graphite-statsd and grafana/grafana).
Just wanted to let you know it is solved in v9.1.7
