I have some data in a mysql data base that is used as datasource. With a query, I get all values of power consumption for each day and I want to show them in a graph, but I did not find how.
With a table panel, I can see this:
But I only can show a graph like this:
The graph is displaying hours, not only days.
This is how my query looks like:
SELECT
last_changed AS "time",
SUM(state) AS "state"
FROM states
WHERE
entity_id = 'sensor.consumo_electrico'
GROUP BY CAST(last_changed AS DATE)
ORDER BY last_changed
Is it possible to show only one bar per day? I am not sure if by hours is the only way…
Thanks
In your Graph you have only one datapoint per date but the time is not the same, you can do something like this:
SELECT
DATE_FORMAT(last_changed '%Y-%m-%d') AS "time",
FROM states
WHERE
GROUP BY DATE_FORMAT(last_changed '%Y-%m-%d')
That totally work! Thanks!
@danielgonzalez the right format of DATE_FORMAT seems to be DATE_FORMAT(date, format)
so the right query should be
SELECT
DATE_FORMAT(last_changed, '%Y-%m-%d') AS "time",
FROM states
WHERE
GROUP BY DATE_FORMAT(last_changed, '%Y-%m-%d')
another little note: I change the Format as from Time series to Table (in grafana)
other than that, it works for me too, thanks @danielgonzalez
Hi, this format that wrong in my query panel, please you can help me? I need a similar panel to this web: Grafana
I need that my panel show the colum of the date.
Thanks!!
