Grant access to dashboard with only one specific variable
Hello there,
I got a dashboard, which contains some variables (in this case: category and URLs):
  "templating": {
    "list": [
        "allValue": null,
        "current": {
          "selected": false,
          "text": "default",
          "value": "default"
        "datasource": "Influx-SP",
        "definition": "",
        "error": null,
        "hide": 0,
        "includeAll": false,
        "label": null,
        "multi": false,
        "name": "category",
        "options": [],
        "query": "SHOW TAG VALUES WITH KEY = \"category\"",
        "refresh": 1,
        "regex": "",
        "skipUrlSync": false,
        "sort": 0,
        "tagValuesQuery": "",
        "tags": [],
        "tagsQuery": "",
        "type": "query",
        "useTags": false
        "allValue": null,
        "definition": "",
        "error": null,
        "hide": 0,
        "label": "group",
        "multi": false,
        "name": "group",
        "options": [],
        "query": "SHOW TAG VALUES WITH KEY = \"group\" WHERE \"category\" =~ /$category/",
        "refresh": 1,
        "regex": "",
        "sort": 0,
        "tags": [],
        "tagsQuery": "",
        "type": "query",
        "useTags": false
        "allValue": null,
        "current": {
          "selected": false,
          "text": "_",
          "value": "_"
        "definition": "",
        "error": null,
        "hide": 0,
        "label": null,
        "multi": false,
        "name": "page",
        "options": [],
        "query": "SHOW TAG VALUES WITH KEY = \"page\" WHERE \"group\" =~ /$group/ AND \"category\" =~ /$category/",
        "refresh": 1,
        "regex": "",
        "sort": 0,
        "tags": [],
        "tagsQuery": "",
        "type": "query",
        "useTags": false
        "allValue": null,
        "current": {
          "selected": false,
          "text": "chrome",
          "value": "chrome"
        "definition": "",
        "error": null,
        "hide": 0,
        "label": null,
        "multi": false,
        "name": "browser",
        "options": [],
        "query": "SHOW TAG VALUES WITH KEY = \"browser\" WHERE \"group\" =~ /$group/ AND \"page\"  =~ /$page/ AND \"category\" =~ /$category/",
        "refresh": 1,
        "regex": "",
        "sort": 0,
        "tags": [],
        "tagsQuery": "",
        "type": "query",
        "useTags": false
        "allValue": null,
        "current": {
          "selected": false,
          "text": "native",
          "value": "native"
        "definition": "",
        "error": null,
        "hide": 0,
        "label": null,
        "multi": false,
        "name": "connectivity",
        "options": [],
        "query": "SHOW TAG VALUES WITH KEY = \"connectivity\" WHERE \"group\" =~ /$group/ AND \"page\"  =~ /$page/ AND \"browser\" =~ /$browser/ AND \"category\" =~ /$category/",
        "refresh": 1,
        "regex": "",
        "sort": 0,
        "tags": [],
        "tagsQuery": "",
        "type": "query",
        "useTags": false
Now I’d like to allow users to see measurements of specific urls. At the moment, the field group shows all URLs and the user can see a list of all urls, no matter if he is supposed to see it or not (of course, this is because the query SHOW TAG VALUES WITH KEY = \"group\" WHERE \"category\" =~ /$category/ returns all entries).
So I’d like to get some best practices to solve this issue. Unfortunately the docs did not help me out :frowning:
Permissions are available on Dashboards and Data Sources, You can create dashboard specific for user and change the variable for each.
Hope it helps.
Good Luck
