Grand Theft Availability, Part 2: Real Monitoring Data + Playable Demo
EggsVice-under-4MB
Well, things have progressed a bit since my last GTA-style experiment inside Grafana. :joy:
I’ve started connecting actual SolarWinds monitored nodes to the buildings, using a read-only SQL query to retrieve their reported status and latest stored metrics. Grafana then uses that data to change how the buildings appear in the 3D world.
So now, when a node reports Down, its building looks like this. Fire, smoke, damaged floors and even emergency vehicles outside.
The fun part is that the other statuses have their own visual treatment too.
Node Unreachable
When a node reports Unreachable, its building gets a different visual treatment rather than appearing as healthy or Down.
Node Up
Healthy nodes remain intact, with green lighting. Selecting a building lets you inspect its reported status and latest stored metrics.
Exploring the city
You can move around the environment, zoom into buildings, change camera angles and investigate individual nodes.
GTAlagoon-under-4MB
And then there’s the island…
Somewhere along the way, I ended up adding another island, a lagoon, an opera house and, naturally, a giant Grafana mascot floating around in the water. :joy:
The whole environment runs inside a Grafana HTML Graphics panel using JavaScript and WebGL2.
The destruction, fires and emergency vehicles are purely fictional visual effects representing reported node status, not actual physical damage or service impact.
Still very much an experiment, but it’s been interesting seeing how far I can push the visual side of Grafana.
Just a quick note: Device names in the screenshots have been replaced with fictional ones.
These are really just fun experiments to explore what’s possible inside Grafana, nothing more. I’m by no means a Grafana expert, just an engineer who’s curious about what it can do and enjoys trying things out :sweat_smile:
Fancy a play?
For anyone who wants to have a play around with this, I’ve attached a community version of the dashboard. :grinning_face_with_smiling_eyes:
This version uses 27 fictional nodes with simulated statuses and metrics, so there’s no need to connect it to SolarWinds or any other monitoring system.
You can change the demo scenarios, select individual buildings, change their statuses and explore the city.
Import
  1. Install the HTML Graphics panel (gapit-htmlgraphics-panel). This export uses version 2.2.3 of its option format.
  2. Open Grafana’s dashboard import screen.
  3. Upload gta-community-v4.6.0.json and import it as a new dashboard.
  4. Give the panel plenty of space or open it full screen. WebGL2 and browser hardware acceleration are recommended.
No external datasource, API keys or additional assets are required.
It’s just a fun experiment to see what’s possible inside Grafana, so feel free to play around with it :fire_engine:
gta-community-v4.6.0.json (528.9 KB)
That’s actually more stylish than that viral vibe-coded “Peter airplane game.”
Even though integrating datasources and field configuration would be difficult with the HTML panel, it got me thinking about how Grafana’s plugin signing system hinders the distribution of community plugins.
Loading scripts from dashboard JSON is a security risk, but what the heck - we pull in tons of MCP servers payload and let agents control our local machines anyway.
The plugin distribution process definitely needs to be simplified, but still sandboxed or sanitized. Otherwise, someone’s gonna embed malware into a dashboard like yours and present it as a GTA 6 leak :slightly_smiling_face:
Haha, thanks mate! :joy:
Interestingly, I haven’t really run into any issues using HTML Graphics with datasources so far. I’ve built another dashboard for my company using the same panel, combining a SQL datasource with Infinity to bring patching activity and infrastructure monitoring into a single timeline.
That’s actually one of the things I’ve enjoyed exploring with Grafana, bringing different sources of information together into something a bit more interactive. Although I might have overlooked some of the difficulties you’re referring to, particularly around field configuration.
I can see what you mean about plugin distribution too. I’ve taken the simpler route of building within an existing panel rather than developing a standalone plugin, so I haven’t really explored the signing process yet.
I do agree with your security point, though. Sharing executable code inside dashboard JSON is something worth being careful about. If there’s a preferred or safer way to distribute something like this within the Grafana community, I’m more than happy to explore it.
I must admit, I only joined the Grafana community 9 days ago, and somehow we’ve already gone from driving around a GTA-style monitoring dashboard to discussing plugin security and malware.
Didn’t quite see that coming :joy:
I wonder if this worth raising as a possible Trojan horse back door security hole grafana needs to plugin. Does the import process scan for possible malware?
@ewamagiera this might be something to bring up to the security team?
This is total madness and I love it! Amazing stuff. Have you looked into also using business text for this? Then you can load the js script from disk instead of embedded in the json itself? @i_like_eggs :egg:
Haha, it’s definitely a little unhinged! :joy: Thank you
I’ve also had a read through the Business Text documentation following your suggestion. I can definitely see the value in hosting the JavaScript files separately on the Grafana server, particularly from a maintainability and reusability perspective.
Really insightful suggestion, appreciate you sharing that :blush:
here is one interesting example @i_like_eggs
Nice work taking this from a fun demo to real monitoring data, and sharing a simulated node version so anyone can try it. The Down / Unreachable / Up building states make status easy to read at a glance. The demo uses 27 nodes. If you’ve tried the SQL backed version with a few hundred, does the query or the rendering slow down first?
