Hi there,
I seem to be misunderstanding how to use GrafanaCloud dashboard embeds in iframes… I can’t turn on embedding within the grafana config or turn on anonymous access within GrafanaCloud as defined in the docs (How to embed Grafana dashboards into web applications | Grafana Labs).
And whenever I try to embed on my website I get the Refused to display 'https://user.grafana.net/' in a frame because it set 'X-Frame-Options' to 'deny'. error message…
So my question is under which conditions is this supposed to work? If I can’t embed into a website because grafanaCloud doesn’t allow ‘X-Frame-Options’, why is the option there to embed? (specifically - I know a normal grafana install would work because you can change the settings)
I don’t understand. Apologies.
