Grafana Zabbix Api
Hi all , we have several zabbix servers and grafana . With zabbix plugin we visualize metrics. Can we get zabbix metrics through grafana api ? Can grafana be for example proxy in this situation ? thx
In the theory yes, but it doesn’t look like a good practice. Especially when Zabbix provides API (check history.get method).
hi, how can i get some metrics through api ? in docs i see only API functions for managment grafana such as add dashboards, users and so on… thx for answer
What exactly do you want? Can you describe your final case?
