Hi all,
could you please help guiding me in configuring Grafana with https ? Our Grafana environment is in Linux CentOS. I have tried some documentation without success.
Thank you so much.
Alexandre.
Hi all,
Thank you so much.
Alexandre.
You’ll need to run Grafana behind a reverse proxy. Grafana itself doesn’t support HTTPS. See http://docs.grafana.org/installation/behind_proxy/#running-grafana-behind-a-reverse-proxy
Hi mefraimsson,
thank you so much for response.
From now, I get courious. What the parameter (protocol = https) in grafana.ini is good for ?
Regards.
Alexandre.
When having root_url = %(protocol)s://%(domain)s:%(http_port)s/ which basically are used for Grafana to understand what the public facing url. There’s a lot of confusion around these settings, but in normal cases we recommend setting root_url = https://<your public facing url>/.
I am trying to configure graffiti by https but they indicate that it is not compatible. Is there any possibility to configure https with certificates to serve the page safely?
I have ubuntu 18, apache and latest version of grafan
I am confused. Which graffiti are we talking about here? Can you give a link
to the project page? I can only find it as a handwriting recognition for Palm
OS, or a rather specialised application used in maths and chemisty…
Who are ‘they’?
page safely?
You can convert HTTP to HTTPS (and vice versa if you want) with a reverse
proxy, and you can convert any TCP protocol to use TLS with stunnel.
Regards,
Antony.
