I follow Grafana docs and I not sure how to configure the Grafana with OpenID connect.
We already configured several applications with OpenID connect which works OK.
What I need is to configure the OpenID connect to Grafana.
What we have:
- ClientID
- Client Secret
- expose Grafana publicly
In addition, we exposed our Grafana publicly and should configure “/redirect” to it.
from the doc This callback URL must match the full HTTP address that you use in your browser to access Grafana, but with the prefix path of /login/generic_oauth"
So we provided this also, my question is what should I do further, what is mandatory ?
Should I create some application or this is just configuration task?
We are using Grafana 7.1 .
As we are not using the following from the example.
Azure AD
BitBucket
Centrify
Okta
OneLogin
