Grafana version 9 OSS unified alerting issue with Azure monitor
    Grafana OSS version 9.2.2
    Create the dashboards and alerts
    With adding Azure monitor as a Data source and get notify on multiple notification contact points using grafana unified alerting
  • What happened?
    Resource names are not visible in unified alerting with using data source as Azure monitor
    In legacy alerting with same configurations, we are getting the Azure resource names which are breaching the threshold values but, after enabling the unified alerting, the resource names does not visible and only their values are and hence, we are unable to understand that, for which resource we are getting notified for
    Azure Monitor | Grafana documentation
Kindly help us and do the needful
Thanks
