Hi All,
lets get this to the point, this might be a bug (?) in the new version (v8)
[previous version] Graph (old) visualization
- transparent color = really transparent
- has override option: z index
[current version] Time Series
*version 8
- transparent color = BLACK → not transparent
- missing override z Index
Table Visualization
- value mappings
I applied value mappings as below, color and text have changed exactly what I want → perfect!
but, why are the other cells also changed into green where there is NO value mapping for that green color?
ANSWER
the green color is because of this option:
set the base to transparent → fix the issue
thanks,
Boyke Ferdinandes
Yes, the lack of a Z-override is really annoying.
My CPU-graph has “idle” almost at the bottom (instead of at the top), and my RAM-graph has “free” between “used” and “cached”. This makes these graphs look rather weird.
Oh, I also noticed that “Negative value” (or whatever it’s called) is also missing, so my network traffic graph has two series that point up, instead of one pointing down.
I ended up using the query ORDER BY to sort the series into the order I want…
Finally got time to look at this again… I have struggled to find good examples of this… I’m using Prometheus as my data-source, and I’ve seen references to “Use Transformations > Organize fields”, but I can’t make that work (“Organize fields only works with a single frame. Consider applying a join transformation first.”)
The query is netdata_system_ram*1024, and I’m trying to sort the four dimensions it returns in a specific order.
I managed to solve it in the end, though I’m not sure why the solution had to be what it was.
I added two transformations to the timelines, first an “outer join” on “time”, then an “organize fields”.
I don’t understand why the outer join is needed, but it works with, and not without, so I’ll just accept that it works now…
does the dev check this forum…?
or is it just us (users) that look at this forum…?
Im pretty new with grafana 2-3 weeks in
so not sure where to post this issue (bug) ?
