Grafana Update: grafana-enterprise collides with grafana
Hello
I am trying to update Grafana 8.5.3 to 9.4.3. Unfortunately I get the following error:
Here the whole log (unfortunately in german)
sudo dpkg -i grafana-enterprise_9.3.0_armhf.deb
dpkg: Betreffend grafana-enterprise_9.3.0_armhf.deb, welches grafana-enterprise enthält:
 grafana-enterprise kollidiert mit grafana
  grafana (Version 8.5.3) ist vorhanden und installiert.
dpkg: Fehler beim Bearbeiten des Archivs grafana-enterprise_9.3.0_armhf.deb (--install):
 Kollidierende Pakete - grafana-enterprise wird nicht installiert
Fehler traten auf beim Bearbeiten von:
I have now made it from 8.5.3 to 9.0.0 and then to 9.2.0. Now I can’t get any further.
Looks like the update will still find the old version (8.5.3)
Does no one have any ideas? I would like to update without deleting and recreating the instance.
You have grafana not grafana-enterprise (they are 2 different products/apps). So install/upgrade grafana app, not grafana-enterprise app.
sorry, my fault,
Have now tried to update to 9.4.7. I don’t get an error, but I didn’t update either. Still 9.2.0.
pi@raspberrypi:~ $ sudo dpkg -i grafana_9.4.7_armhf.deb
(Reading database ... 116730 files and directories currently installed.)
Preparing to unpack grafana_9.4.7_armhf.deb ...
Unpacking grafana (9.4.7) over (9.2.0) ...
Replaced by files in installed package grafana-enterprise (9.2.0) ...
Setting up grafana (9.4.7) ...
Restarting grafana-server service... OK
Processing triggers for systemd (241-7~deb10u8+rpi1) ...
