Grafana teams incoming webhook connection Refused
Hi, I am using Grafana v9.1.7.I was trying to create alert in our organisation teams channel using incoming webhook. But when I configure the webhook url in the grafana and try to send a test alert the test alert fails.
Exact error: [12:54] Tejaswy, Sai
Failed to send test alert.: send notification to Teams: Post "https://unilever.webhook.office.com/webhookb2/7fd180ec-cee8-45c1-a234-8827f0a79f2e@f66fae02-5d36-495b-bfe0-78a6ff9f8e6e/IncomingWebhook/48a904f5509e4b6ea7c01f42fcaf6bfa/911ec7bc-d9ca-4715-abbb-88f3291233c0": dial tcp: lookup *****.webhook.office.com on [::1]:53: read udp [::1]:59663->[::1]:53: read: connection refused
Can someone help me to solve this issue?
@sai23 Welcome to the Grafana forum.
Just to clarify, are you just trying to use a regular webhook in your alert? What is the URL that you posted?
@grant2 No I Chose Microsoft teams as contact point and entered the incoming webhook url created from our teams channel. I will attach a picture so you can understand better.
@sai23
Can you determine if your MS Teams webhook works from another application (besides Grafana)? The error message shown ends with “connection refused” so I am thinking there is something (firewall setting, etc.) that is not allowing your webhook to go through.
@sai23 If you have found a solution, can you please share here?
Hey @grant2 , sure I can. I tried what you said , the webhook works with other applications , So we figured out it’s some problem within our organisation’s firewall. We figured we can sort that out
Good to know. I also struggled with a similar webhook issue where the device receiving the webhook would not permit it due to some sort of HTTP security block. My workaround was to send the webhook to Node-RED running on the same server that is runnning Grafana, then transmit the message via MQTT to the other device (which was blocking the webhook).
Thank you so much helping me with it! We have similar issues which you have, So our team is working on the issue. This helps, thank you for mentioning.
