Hello Everyone,
Not sure if anyone has experienced this before - But since i am using Table plugin on Grafana with Google Cloud Monitoring as a Data source - The number of records right after appliying SeriestoRow Transformation gets duplicate - Now i can use “Group by” at the later stage but as soon the data flow gets huge in quantity its causing impact on Load time - and the multiplication of per record is as follows:
- After SeriestoRow Transformation every record gets multiplied by 2
What Grafana version and what operating system are you using? v8.5.1 and Windows
What are you trying to achieve? Accurate Data and Optimized way
How are you trying to achieve it? Using Google Cloud Monitoring Plugin and Table Plugin
What happened? Data get’s multiplied causing Grafana to not load details when huge amount of data is processed.
What did you expect to happen? One row per record
Can you copy/paste the configuration(s) that you are having problems with? N/A
Did you receive any errors in the Grafana UI or in related logs? If so, please tell us exactly what they were. N/A
Did you follow any online instructions? If so, what is the URL? N/A
