I’m trying to configure Grafana on k3s v1.29.1+k3s2 with NFS as PersistentVolume. Grafana correctly connects to NFS server, but container stucks on “Starting DB migrations”
Logs
logger=settings t=2024-02-29T19:49:37.442908249Z level=info msg="Starting Grafana" version=10.3.3 commit=252761264e22ece57204b327f9130d3b44592c01 branch=HEAD compiled=2024-02-29T19:49:37Z
logger=settings t=2024-02-29T19:49:37.443176042Z level=info msg="Config loaded from" file=/usr/share/grafana/conf/defaults.ini
logger=settings t=2024-02-29T19:49:37.443191963Z level=info msg="Config loaded from" file=/etc/grafana/grafana.ini
logger=settings t=2024-02-29T19:49:37.443200157Z level=info msg="Config overridden from command line" arg="default.paths.data=/var/lib/grafana"
logger=settings t=2024-02-29T19:49:37.443207974Z level=info msg="Config overridden from command line" arg="default.paths.logs=/var/log/grafana"
logger=settings t=2024-02-29T19:49:37.443215618Z level=info msg="Config overridden from command line" arg="default.paths.plugins=/var/lib/grafana/plugins"
logger=settings t=2024-02-29T19:49:37.443223741Z level=info msg="Config overridden from command line" arg="default.paths.provisioning=/etc/grafana/provisioning"
logger=settings t=2024-02-29T19:49:37.443232428Z level=info msg="Config overridden from command line" arg="default.log.mode=console"
logger=settings t=2024-02-29T19:49:37.443241975Z level=info msg="Config overridden from Environment variable" var="GF_PATHS_DATA=/var/lib/grafana"
logger=settings t=2024-02-29T19:49:37.443249988Z level=info msg="Config overridden from Environment variable" var="GF_PATHS_LOGS=/var/log/grafana"
logger=settings t=2024-02-29T19:49:37.44325752Z level=info msg="Config overridden from Environment variable" var="GF_PATHS_PLUGINS=/var/lib/grafana/plugins"
logger=settings t=2024-02-29T19:49:37.443265604Z level=info msg="Config overridden from Environment variable" var="GF_PATHS_PROVISIONING=/etc/grafana/provisioning"
logger=settings t=2024-02-29T19:49:37.443273678Z level=info msg=Target target=[all]
logger=settings t=2024-02-29T19:49:37.443293755Z level=info msg="Path Home" path=/usr/share/grafana
logger=settings t=2024-02-29T19:49:37.443303064Z level=info msg="Path Data" path=/var/lib/grafana
logger=settings t=2024-02-29T19:49:37.443310362Z level=info msg="Path Logs" path=/var/log/grafana
logger=settings t=2024-02-29T19:49:37.443318619Z level=info msg="Path Plugins" path=/var/lib/grafana/plugins
logger=settings t=2024-02-29T19:49:37.44332657Z level=info msg="Path Provisioning" path=/etc/grafana/provisioning
logger=settings t=2024-02-29T19:49:37.443334271Z level=info msg="App mode production"
logger=sqlstore t=2024-02-29T19:49:37.443615487Z level=info msg="Connecting to DB" dbtype=sqlite3
logger=migrator t=2024-02-29T19:49:37.44454707Z level=info msg="Starting DB migrations"
Deployment
apiVersion: apps/v1
kind: Deployment
metadata:
labels:
app: grafana
namespace: grafana
spec:
selector:
matchLabels:
app: grafana
template:
metadata:
labels:
app: grafana
spec:
securityContext:
fsGroup: 472
supplementalGroups:
- 0
containers:
- name: grafana
image: grafana/grafana:10.3.3
imagePullPolicy: IfNotPresent
ports:
- containerPort: 3000
protocol: TCP
readinessProbe:
failureThreshold: 3
httpGet:
path: /robots.txt
port: 3000
scheme: HTTP
initialDelaySeconds: 10
periodSeconds: 30
successThreshold: 1
timeoutSeconds: 2
livenessProbe:
failureThreshold: 3
initialDelaySeconds: 30
periodSeconds: 10
successThreshold: 1
tcpSocket:
port: 3000
timeoutSeconds: 1
resources:
requests:
cpu: 250m
memory: 750Mi
volumeMounts:
- mountPath: /var/lib/grafana
volumes:
- name: grafana-pv
persistentVolumeClaim:
claimName: grafana-volume-claim
Volume
apiVersion: v1
kind: PersistentVolume
metadata:
spec:
capacity:
storage: 1Gi
volumeMode: Filesystem
accessModes:
- ReadWriteMany
persistentVolumeReclaimPolicy: Retain
storageClassName: ""
mountOptions:
- hard
- nfsvers=3
nfs:
path: /mnt/data/k8s/grafana
server: 192.168.1.11
VolumeClaim
apiVersion: v1
kind: PersistentVolumeClaim
metadata:
namespace: grafana
spec:
accessModes:
- ReadWriteMany
volumeName: grafana-volume
resources:
requests:
storage: 1Gi
NFS Configuration
/mnt/data/k8s/grafana 192.168.1.15(rw,all_squash,sync,no_subtree_check) 192.168.1.16(rw,all_squash,sync,no_subtree_check) 192.168.1.18(rw,all_squash,sync,no_subtree_check)
