What Grafana version and what operating system are you using? Grafana v12.3.6 running on K8s. Pod running Alpine Linux v3.23.
What are you trying to achieve? Security test found snapshots can be deleted by any authenticated user. We need to better control the permissions of who can delete existing snapshots.
How are you trying to achieve it? We need to make snapshot deletion more secure or just disable the feature/function.
What happened? Any signed-in user that acquires the delete key can delete the snapshot without snapshot-delete permission. On deletion, it lacked permission checks allowing low-level user to execute and delete the snapshot.
What did you expect to happen? Some permission check to avoid any authenticated used to delete snapshots.
Can you copy/paste the configuration(s) that you are having problems with? N/A
Did you receive any errors in the Grafana UI or in related logs? If so, please tell us exactly what they were. No error, the deletion was performed successfully.
Did you follow any online instructions? If so, what is the URL? No.
In this issue on Grafana 12 on Alpine Linux (Docker)
A viewer user can delete any snapshot just by knowing the delete key - no permission check
so for increasing safety purpose we need to disable snapshots in grafana.ini
[snapshots]
enabled = false
For K8s deployment add as environment variable
env
name GF_SNAPSHOTS_ENABLED
value “false”
now the user is blocked which means now any user cannot delete snapshot
