Grafana sigv4 authentication
Hello, we have a problem setting up aws-sigv4 and connecting an AWS AMP workspace via docker images.
TAG: grafana/grafana:7.4.5
Main problem is that in the UI the sigv4 configuration screen does not appear.
Installing grafana:7.4.5 locally via Standalone Linux Binaries works.
Just setting the environment variables,
export AWS_SDK_LOAD_CONFIG=true
export GF_AUTH_SIGV4_AUTH_ENABLED=true
the configuration screen appears.
Connecting and querying data to AMP via corresponding IAM instance role is working flawlessly.
Doing the same in the docker image as ENV Variables does NOT work.
When using grafana/grafana:sigv4-web-identity it works, but it seems to me that this is just a “test image”.
How to configure the default grafana image in order to enable sigV4 authentication?
Observing the same issue, can someone help please.
This option must be enabled in grafana.ini
[auth]
sigv4_auth_enabled = true
