Grafana -> share -> Direct link rendered image -> no data
Hello.
I’m calling grafana using a proxy from an IP site that doesn’t have a domain.
This is the result of rendering.
/render/d-solo
/d-solo
No data, only images come out.
Hi @daemonjaejin10,
What reverse proxy are you using? Can you share any details about your proxy/networking configs? Also, what grafana version and OS are you running?
Hi @anon70503803
I am using apache proxy.
I am using linux centos.
The grafana version is 6.4.0.
no rendering
rendering
Only the image is displayed, the text is not.
Hi~ @anon70503803
The above link solved the problem.
Thanks for Regard.
