- How much data volume can Grafana handle ? can it handle terabytes of data ?
- Can Superset perform near real time reporting , example reports should display updated data within 5-10 minutes? how to achieve this in Grafana
- How many users are supported by free edition of Grafana ? how many maximum number of users can view report at same time?
- Can Grafana be installed on AWS Cloud network as PaaS solution?
- Does Grafana provides capability to create Paginated Reports which is easy to Print with multiple pages like Bank statements or contracts etc
- what are the AI features available in Grafana ?
- Can I create multilingual reports or reports which chart or title labels in other languages apart from English in Grafana , how to achieve this?
- Can it be possible to convert Looker reports onto Grafana?
Yes → Grafana can handle all of those use cases, with a few limitations
Data volume: Grafana itself is a visualization layer; scalability depends on the backend (for example → Grafana Mimir, ClickHouse, Snowflake, PostgreSQL, etc.).
Grafana deployments can scale to terabytes of data, depending on the backend used.
Near real-time reporting (5–10 min): Yes. Set the dashboard Auto refresh interval (for example 1m or 5m) and ensure your data source is updated within that timeframe.
Free edition users: Grafana OSS has no built in user limit and no fixed concurrent viewer limit , the practical limit depends on server and datasource capacity.
AWS PaaS: Yes Amazon Managed Grafana is the fully managed AWS offering.
Paginated reports: Grafana Enterprise/Cloud Reporting can generate PDF reports from dashboards, but it is not intended for creating highly formatted, paginated business documents such as bank statements or contracts.
AI features: Grafana offers AI capabilities such as Grafana Assistant and AI-powered investigations and observability features. Availability depends on the Grafana edition and licensing.
Multilingual dashboards: Dashboard titles, panel names, and labels can be written in any language, but Grafana does not provide automatic translation of dashboard content.
Looker migration: There is no automatic Looker to Grafana dashboard converter. Existing Looker reports/dashboards generally need to be recreated manually. If appropriate for your setup, Grafana can query Looker data using the Looker data source plugin.
