Grafana Query question
Hello, I’m using graphite with grafana and I’ve created some metrics that store data in graphite in the form of:
ADStatus.ADDefault.USERNAMES.LockedOut (data will be a 0 if not locked out or 1 if locked out) TIMESTAMP
I have a script that queries our AD and checks each user and their locked out status.
I want to have a table that will show locked out users (if their value is 1).
I’m not sure how to build this query though…so far I have:
“aliasByNode(highestCurrent(ADStatus.ADDefault.*.LockOutStatus, 5), 2)”
But this just displays the ‘top 5’ regardless of their value…(all are 0 except 1 for testing).
How would I do a query like…
ADstatus | ADDefault | * | LockOutStatus | WHERE VALUE = 1 | aliasByNode(2)
Is this possible?
Think these kind of things are hard to do using graphite. Also depending on your number of users you may hit a problem with high cardinality of usernames in your metrics (a limitation that many time series databases have). In your case it would be much easier to use a relational database like Postgres, MySQL or MSSQL or Influxdb (which is a time series database).
Marcus
Thanks Marcus,
I guess even if I were using SQL or another DB I’m not sure how to build the query to still show the users when locked out…
I figured it would be easy to have a table display ONLY the items where a value was 1 and not 0
Yes table and query where lockedout = 1 are probably the easiest.
Marcus
Ahh this is great! I wasnt even aware we could honestly use SQL with grafana…
When I go to >Datasources > Add a data source i dont see SQL in the drop down in type…am I missing a step on adding an SQL Db?
Nevermind I see it says only avail in 5.1+, I’m using 4.2…I’ll have to look for an easy way to upgrade
I was able to find version 5.0.3 but I am unable to find 5.1
This linke: http://docs.grafana.org/v5.1/features/datasources/mssql/
shows that the MSSQL is only available in 5.1…where can I find this download?
Either nightly builds or building from source.
Marcus
