Info:
Grafana version 9.4.7
I’m trying to visualize data from SAP Data Intelligence source, for the metric labels I’m seeing the technical description of the fields and they do not provide meaning.
Is it possible to do some configuration to get the description in Grafana instead of the technical ID, is it some configuration to do in Grafana Data Source or is something to check from the Data Intelligence source?
Many thanks for your help
