Grafana Problem unter Lxc Container Proxmox
  • Which grafana version and what operating system you use?
  • Was versuchst du zu erreichen?
  • How you to be at reach it?
  • What’s happened?
  • What you erwartet that would happen?
  • Can do you copy/inse the configuration(s with you have problems?
  • Have have bugs in the grafana user uer user or related protocols? If ya, please tell us genau what they were.
  • Have have on-line instructions? If yes, was is the URL?
Hallo
I have a problem with my Lxc container.
I have Grafana drauf und wollte von Version 11.3 auf 11.2 herunterstufen, weil in ioBroker die Dashboards nicht aktualisiert werden. Then I go to the Shell and had feststellen that my Debian needs to be updated. But I just do not t t ent. I have no idea what to do.
I could very happy if someone could me say the commands how I can the update.
[Gitter]
Hochladen: IMG_0023.png…
Hochladen: IMG_0022.png.IMG_0021ng…
[/Gitter]
