10.1.1
Gentoo -
I’m trying to build Grafana on my system, then pack it into a LXC container -
I’ve created a basic container environment based on glibc with tini, I want to “install” grafana into this environment. -
What happened?
I can’t figure out how to install grafana from the repo instructions. -
https://github.com/grafana/grafana/blob/HEAD/contribute/developer-guide.md
